Laguna Shear Force Bandsaw Blade http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=22571 |
Author: | KHageman [ Sun May 31, 2009 2:26 am ] |
Post subject: | Laguna Shear Force Bandsaw Blade |
Greetings, Has anyone ever used the Laguna Shear Force Bandsaw Resaw Blade. From the description on their Website, the blade seems very similar to the thin kerf blade sold by Highland Hardware in Atlanta. Variable spaced teeth, low noise, thin kerf, etc. The two blades are very similar in cost, about $30.00 each for a 105 inch blade (Delta/Rockwell 14 inch with riser block). I am interested because Laguna has a buy one get another free offer on ebay. That makes the blades cost about $15.00 each and seems like a great deal if they are any good. Please advise. Thanks Ken Hageman |
Author: | DannyV [ Sun May 31, 2009 9:46 pm ] |
Post subject: | Re: Laguna Shear Force Bandsaw Blade |
I bought and tried one and liked it enough to buy two more on the two for one deal. Pretty good value. You might want to check the Laguna web site because they had some free shipping deals as well as two for one. Cheers, Danny |
Author: | Bill Hodge [ Mon Jun 01, 2009 11:23 am ] |
The BOGO on ebay is a fair deal but I've found that Spectrum Supply actually has the best pricing. I have two of their Kerf Master blades and two of the Highland Woodworking (HWW) WoodSlicer. They are exactly the same blade and both are manufactured by Lenox. I suspect that the Shear Force blase is as well. HWW sells the wood slicer in the 161" size that I need for $49 and the same Lenox blade from Spectrum Supply cost me $22 so I got two for less than the price of the one at HWW. Their every day price for the 105" x 3/4" Kerf Master is $17. Wish I had known that before buying the WoodSlicer. I have been extremely pleased with the performance and longevity of these blades as resaw blades. |
Author: | KHageman [ Mon Jun 01, 2009 10:56 pm ] |
Bill, I looked up the "wood master" blade at "Spectrum Supply". I would bet you are correct that all three blades you mentioned are pretty much or exactly the same. I see that Spectrum has a wood master blade that is 5/8 inches with a .016 kerf. That is really thin. Do you have any experience with this thin kerf blade. I see all the other widths and even another 5/8 inch blade have the standard .21 thin kerf width. Thanks Ken |
Author: | Bill Hodge [ Tue Jun 02, 2009 7:51 am ] |
Howdy Ken, I assume you meant the Kerf Master. ![]() ![]() |
Author: | Link Van Cleave [ Tue Jun 02, 2009 9:18 am ] |
Bill, .015, are you sure. That is a 1/64". There is a blade that will cut a 1/64" kerf ? Where have I been, I want one. Link |
Author: | Bill Hodge [ Tue Jun 02, 2009 9:25 am ] |
Howdy Link, Yep it's in the link (no pun intended ![]() ![]() ![]() |
Author: | efialtis [ Tue Jun 02, 2009 9:34 am ] |
I think the .16" refers to the blade thickness not the kerf. |
Author: | Bill Hodge [ Tue Jun 02, 2009 9:52 am ] |
It's .016 and that spec is the thickness, true. However, with the design of these specific blades, the kerf is only .002 to .003 more. So minute a difference it's laughable. ![]() ![]() ![]() |
Author: | efialtis [ Tue Jun 02, 2009 10:06 am ] |
Thanks' for the info.I realized I left out a zero after I posted. I'm surprised that the set of the teeth is that small as the woodslicer adds .009" to the .022" bade thickness. |
Author: | Bill Hodge [ Tue Jun 02, 2009 10:09 am ] |
Yes the Wood Slicer does add a bit more. ![]() ![]() |
Author: | efialtis [ Tue Jun 02, 2009 10:13 am ] |
I'm ordering a couple today, thank's for the heads up! |
Author: | Bill Hodge [ Tue Jun 02, 2009 10:59 am ] |
One thing that I must note and correct myself on a bit is that on softer woods, it will take a slightly thicker kerf (+.004) than it does on the harder varieties of wood. I don't really know the physics behind it but I believe we have a physicist or two in the OLF who could explain that if they wanted. ![]() |
Author: | KHageman [ Tue Jun 02, 2009 12:17 pm ] |
Thanks to everyone for their input. I have the Shear Force blades on there way, but will try the Kerf Master next time around. Ken |
